New Software Updates Discussion Thread | Page 9 | SatelliteGuys.US
Oh, I missed that letter - is Dish attempting to use Linux based code on the old platform ? Compliance to TiVo lawsuit ?
Interesting take, anything is possible. The receivers on the field (P401 - P404) are getting L405, they've been using Pxx for their 5xx receivers and they're now switching to Lxx.
Two separate PIDs, '
Isn't it unusual to make this sort of change?
It's been P since the beginning, and now suddenly the switch to L.
For that matter why the distinction at all. The ones getting P are the older versions and I think anything needing the initial download/update.
L looks like the start of a normal test/rollout.
L405 doesn't show up anywhere in the Dish software chart. Must be a stealth release.
They have this in the Tech Portal but they list L405 in the title and P405 in the description.
3/10/2008: 1342 Software Version L4.05 for DP 501/508/510
Effective Tuesday, March 11th, Engineering plans to spool a PARTIAL PHASE of software version P.405 for the DP501, 508, and 510 receivers. This is primarily a non-forced maintenance release available at ALL satellite locations.
At this time P4.03 and P4.05 will be the valid software versions for the DP 501, 508, and 510 .
Like Hall, maybe the DVRs had not been updated after all:
TiVo: EchoStar Risking Contempt Proceeding
I still have P3.69. When P4.01 was released to everyone, both were "valid" and there has not been a forced update yet.
So, is P3.69 no longer "valid"? does that mean I'll be getting a forced update soon?
Has been discovered - DP422 is real model ID, while ViP222 is marketing name of it.
Same idea applied to DP642 - it was named as ViP612.
Man, how Dish like to twist lines and names. :(
P always was a production version for OpenTV models, opposite to old type with 4 digits, like 708P.
L and M using for Linux based models ( M by 2WIRE ).
2WIRE? My DSL modem/router is made by them, but what did/do they make for DIsh?
PID: 0867h, ID: 85SD, FW: P405, Model: PVR5xx.
PID=0867h
DownloadID:'85SD'
New FW:'P405'
Looks like they changed it. Must of been a typo?
"Looks like they changed it. Must of been a typo?"
That's what it looks like. Smith checked both bin files and they are the same for both PIDs. Someone made a type mistake at E*.
For notes on the software updates, we'll need Scott to post them or E* to send them to him. I haven't seen any release notes and we've had quite a few software updates this week.
Does Dish publish what was updated/new features, etc for the updates or they just sent to Scott?
Would be interesting to find designated letters in spooling FW IDs.
For sure third letter "T" means test.
There should be a sign of mandatory and not, phase spool or for all.
I just saw this in the Tech. Portal. I'm just wondering if they will finally turn on the EHD on the 211s. Team Summit is coming soon so I'm hoping this is it.
5/7/2008: 1000 Software Version L4.38 for ViP 211/DISH 411
Effective Thursday, May 8th, Engineering plans to spool a PARTIAL PHASE of software version L4.38 for the ViP 211/DISH 411 receiver. This is primarily a non-forced maintenance release available at ALL satellite locations.
At this time L4.37 and L4.38 will be the valid software versions for the ViP 211/DISH 411.
Nope it's not.
The initial notes I have on the new software is as follows:
Thursday 5/8
ViP211/DP411
L438
100K Partial (Tentative)
12AM
External card/241 Swap Support, Eastern Arc/Future Sat Support, Favorites List EPG Pop-up, Regional Uplink Outage indicator, Mode Reminder Pop-up 908 with menu option, check switch UI updates/verbiage, STBHL.
Replacement 722
DirectTV dish on Dish Network system
