Help, My Laptop Has Been Hit With Some Nasty Spyware Thingy! | Page 2 | SatelliteGuys.US
Sure, the recovery disks, or recovery partition, will get it back to factory settings, if that's actually what you want. Factory settings is my biggest gripe with big-vendor computers and is only slightly less annoying than a malware infection.
First thing I do with a new computer is delete the partition and install a clean OS without all that bloat crapware they preload. If I really want google toolbar, or a desktop search app or a particular media player, I'll install the one I want, thanks a lot.
I too would save factory reset as the LAST RESORT.
The OP said that he had just started sorting out a NEW computer. I posted my suggestion based on that. This piece of malware is especially nasty, and frankly he stated he isn't at your level of savvy. I really believe in this particular instance, he is better off.
So this brings up the question, what do we all use to protect our computers?
Personally, I used Spybot, Adaware, and AntiVir XP. I haven't had a problem in 6 years (knocking on head...I mean wood :p)
Macintosh, Firefox, and not surfing bad sites does nicely.
Best Way to Record LP's to MP3?
Router
