lnbf for CM | SatelliteGuys.US
lnbf for CM
new-2-fta
12
My old Channel Master had a lnb mounted in a 40mm clamp can a lnbf be used in its place. where the old feedhorn used to be.
yes it will work. People do it all the time. I did it on my Primestar dish
Hey Ice, does the signal suffer any due to the fact that the OEM feed sits closer to the dish than an aftermarket LNBF. I always wondered about that since on my 90cm P* the factory feed is matched to the dish. I would think you would over illuminate the dish and pick up thermal noise.
Thanks I must have created new post these forums are all new to me. I will chatch on sooner or later.
not really. I have a P* at G11 and when the factory LNB blowed up I temporarily swapped it with a regular LNB (gutted so it would fit on the 25mm spot) and the signal was the same. I have tried 3 or 4 LNB's on there and they all are the same
The flange is still the best though. They bolt right on there :)
Cool... An Invacom could work very well since the struts can handle a heavy Lnbf.
tv on computor
new sats
