Is your local RSN included in Direct TV's packages? | SatelliteGuys.US
Yes you local RSN(s) should be included without the sports pack. And depending on what package you get, you may get neighboring RSNs too (we here in Buffalo get the Cleveland RSN for Indians games starting this year if we have the Choice Xtra pack or higher - no sports pack required).
What is your ZIP?
zip is 15845
At your zipcode, the only one you'd get in the basic package is FSN Pittsburgh.
With Choice Xtra you'd get STO, and with Premier you'd get FSN Ohio.
With any DIRECTV base package (CHOICE or above):
FSN Pittsburgh (Ch. 628)</B>
<LI type=square>Pittsburgh Penguins (HD Available)
<LI type=square>Pittsburgh Pirates (HD Available)
With the Premier package or any DIRECTV base package plus SPORTS Pack, you also get:
FSN Ohio (Ch. 637)</B>
<LI type=square>Cleveland Cavaliers (HD Available)
With the Choice Xtra package you also get:
Sports Time Ohio (Ch. 657)</B>
<LI type=square>Cleveland Indians (HD Available)
You get your local RSN's with the "Choice" package or Higher. Family pack will not give you any RSNs.But for $12 you can get the sports pack added to your family pack. Then you would get all RSN's
DirecTV Info for March Madness 2008 Package
FSN North and Wisconsin Swapped
