Great tip! I went to Amazon and found this angle locator:
Amazon.com: Johnson Level & Tool 700 Magnetic Angle Locator: Home Improvement
And guess who wrote the first customer review!
Excellent tool
We use this for satellite dish installation, and we are very please with its quality and durability. It is not like the cheap imported models. This is much more precise and the scale if very easy to read. We highly recommend it to all of our dish installers. For the price and quality, it is a 5 stars no doubt.Best regards
Sadoun Satellite Sales
Wow, you found our review from a few years ago. Well, the review still stands. Johnson Level & Tool good ol' American quality is top.
Here is the link to the level from our store.
iafirebuff, I am not sure how Farm and Fleet sells it for $6? That is seriously below our cost. You must have bought it on sale.
They are identical to the Johnson Level only they have a black case.![]()
I remembered this comment, and now I see ThisBUD has photographed the idea.... So I reset my elevation placing a yard stick from the bottom lip of the dish to the top on the lnbf.
Then I put my inclinometer on the yard stick and set my elevation angle exactly to what my satellite calculation program on my computer said.
Then I slow moved the dishes azmuith and bang it was there.
Not sure of the basis for the assumption, but can see some fallacies in the implementation.
For one, the LNB horn diameter as well as its in/out placement, will vary your angle.
Also, on dishes which don't have tripod LNB-mounting (side stabilizer struts), the LNB could be high or low by a number of degrees, which is the basic reason the dish elevation marks are in error.
I ended up buying the Sears Craftsman angle finder in the pictures. What I like about this one is the little red markers that slide around to mark the angle you want. The elevation indicators on the dish just aren't accurate enough. Without one of these angle finders you're flying blind, IMO.
When I first tried this (on G25 yesterday) I didn't remember the description of the method correctly and put a straight edge across the reflector from top to bottom. That didn't work AT ALL and I realized that gave a totally different angle than what was on the elevation marks. Next I ran the straight edge from the top of the dish down to the LNB and that worked and for some strange reason gives the same angle as you get when you go from the bottom of the dish to the LNB. Today when I was trying to get G10 the dish was mounted on plywood up on sawhorses which I didn't make much of an attempt to get really level (I did put a piece of wood on one side to shim it up to where it looked approximately right) - the point being that there was no reason to think that the elevation marks on the dish were even close to being right. So using this yard stick and protractor method will get you close enough to get signal, which is most of the battle. You still have to tweak it from there, in tiny little increments. For the elevation I just leaned on the dish a little up or down to see which way to adjust it - it was just a tiny little adjustment needed from where I had set the elevation originally.I remembered this comment, and now I see ThisBUD has photographed the idea.
The way I have used an inclinometer, is by using the offset degrees of the dish (Azure Shine 90cm is 24.6°) subtracted from my desired elevation and using that number for the front of the rim of the dish.
So if I wanted 33° elevation I would take 33°-24.6°=8.4°.
On my inclinometer, vertical reads 90°, so 90°-8.4°=81.6°.
I set the red marker to 81.5°, stick it to the front/side of the rim (using the magnet) and I am ready to set my elevation.
Note: this only works on dishes that don't skew.
You lost me here. Where do you get the offset degrees of the dish? Where do you put the angle finder? Can you post pictures of how this works? ThanksThe way I have used an inclinometer, is by using the offset degrees of the dish (Azure Shine 90cm is 24.6°) subtracted from my desired elevation and using that number for the front of the rim of the dish. So if I wanted 33° elevation I would take 33°-24.6°=8.4°. On my inclinometer, vertical reads 90°, so 90°-8.4°=81.6°. I set the red marker to 81.5°, stick it to the front/side of the rim (using the magnet) and I am ready to set my elevation.
Bob
Limited time offer
