I just recently moved to Great Falls Montana I have a dish 1000 and a single dish and I'm trying to pick up the hd locals on 61.5 on my single dish but my receiver is not picking it up anyone has any answers
The only HD locals on 61.5 are Boston, NY, Philly and DC. You would have to "move" to one of those locations in order to receive their HD locals.I just recently moved to Great Falls Montana I have a dish 1000 and a single dish and I'm trying to pick up the hd locals on 61.5 on my single dish but my receiver is not picking it up anyone has any answers
if you plan on keeping 129 as well.... you need a DPP44 switch
Ok if you don't want to keep 129 run a wire from the dish at 61.5 to the sat-in port on the DPPlus Twin on the 1000. Make sure you are using a DP dual on the 61.5 sat if it is old take the one off the 1000 for 129 and put it on that dish.
If it says Dish Pro you are good to go![]()
my Receiver is still not picking 61.5 up dont know what i can be doing wrong
I would just go directly from the 61.5 lnb to the receiver and try to aim it, once you get it aligned then make the proper connections and run check switch.
how far should i swing the dish to the right and should i set the azimuth, elevation and skew even wit me using a dish 500 as a wing dish
Where in Montana are you located? Someone in your other thread pointed you to a satellite position calculator.
For Great Falls, I"m getting:
Azimuth 121.9
Elevation 17.5
Echostar 5 at 110 W is at 178.2 so you need to look at where your D500 is aimed and swing it to your left if you're standing behind the dish.
The elevation sounds kind of right because I'm in the Bay Area and my elevation is really low, 14.1. So the dish looks like it's pointing to the ground. Just make sure your mast is level.
the 61.5 is the wing dish so its not on the other dish its by itself so if i'm standing behind it do i turn it toward the other dish or away the other dish has the 119/110 so i'm thinking i'm suppose to turn it away
You realize that this will only work until the spotbeams on E12 go active and the NY locals are moved from CONUS to spotbeam.... but i wanna pick up 61.5 cause i did the move to NY so i want their hd locals
Limited time offer
