IR Blaster Cable | SatelliteGuys.US
IR Blaster Cable
Does anyone know of place that sells long IR Blaster Cable? I need one about 30 foot long. Thanks.
Get one like this: MythTV LIRC RS232 IR Blaster (scroll to bottom of that page)
You need to buy an IR blaster like that, that has a standard 1/8'' (headphone) jack.
Then go to Radio Shack and tell them you need 30' headphone extension cord that has a coupler on one end. (it will look like this, only in a longer size) If they don't have any longer, just get 2 short ones (like the one linked above is 16ft, so buy 2 of them, (thats 32ft) and the couplers are built into the cable!)
The plug is the same as a headphone jack, so the cord should work through the extension.
Let me know if that works out!
-Scott
-Scott
OK, thanks Scott. Got a busy week. Will check into your info this weekend.
-Scott
Hello. I have a similar problem; however, my Panasonic DVD recorder IR Blaster has 3 bands on the plug end, not the 2 as appears to be the case here.
Any suggestions?
Thanks.
Go to homedepot or an electrical store and get some doorbell wire or 22-4 wire. CHEAP. Cut it and splice it color for color. I have spliced at least 300 blasters and have never had a problem. I personal use 22-4 or CAT5e depending on how many blasters are going to the same spot.
IS THERE A TOOL THAT GIVES THE PHONE LINE TONE TO THE DUAL TUNERS?
Help just lost drive- should we sign up for warranty
