It's digital... you either have the picture or you don't.
As long as Hollywierd has Congressional Democrats in their pocket DMCA will keep being pushed, revised, enforced by the might of the U.S. Federal Gubmint."Congressman 'Hollywood' Howard Berman (D-CA) used a House subcommittee hearing today to express his view that the DMCA was in need of a rewrite. In his view, it doesn't go far enough. During his opening remarks for a hearing on the PRO-IP Act, Berman said that the DMCA's Safe Harbor needs further scrutiny and that it might be time to make filtering mandatory. There's more: Berman also 'wants to examine the "effectiveness of takedown notices" under the DMCA, and he'd like to take another look at whether filtering technology has advanced to the point where Congress ought to mandate it in certain situations.'"
I purchased a HDMI switch today, and will be getting it soon.
To those who use it already, I have a question:
Does it affect the PQ compared to straight HDMI connection?
Semms to me you don't know what HDMI or DVI port means - the 722 DOESN'T have DVI connector.
I think we can presume that his TV has the DVI connection.Semms to me you don't know what HDMI or DVI port means - the 722 DOESN'T have DVI connector.
Thank you. From what I've read, my TV should be HDCP compliant over DVI.HDMI is just DVI + Audio. Very easily split with an adapter.The real question is: Does the TV support HDCP over DVI or not?
Dish will have to do something on their end (in the receiver's software). I'm curious how they'll test this though as they can't do anything until the flag exists in the stream from the providers. The resolution setting will remain as it is today. It has to be "correct" or as the user wants for non-protected programs and you can't change the resolution "on the fly" anyway.So are they gonna implement this via software update, and do it like my upconverting DVD player, and disable resolution selection via component and set it to 480i or 480p by default?
Could you please correct your own post in that part what show DVI instead of HDMI related to 722 ?Thank you. From what I've read, my TV should be HDCP compliant over DVI.
Right and until Dish updates software on the receivers, the flag will simply be ignored.They could 'inject' the flag any time for that current DRMx channels. No one customer will affected.
Limited time offer
