HR20-700 {CE:10:05} - 0x1D? Issues | SatelliteGuys.US
goaliebob99
14,487
521
Systems in this CE / Version
Software Download Window:
Friday; December 7, 2007 11PM - 2:30AM ET
Saturday; December 8, 2007 11PM - 2:30AM ET
Be sure to monitor the threads and chat room to check on final availability
MUST READ AND AGREE TO: - The CE Rules, Faq and Tips Thread... Here
Please join "us" in the CHAT room, about 15 minutes before the window opens... and till... well to the last person turns off the lights...
DBSTalk.Com -
Important notes regarding this version
This is a very aggressive CE cycle.
And with that, there is a SIGNIFICANTLY increased level of risk involved with this version.
There is LITTLE risk that your box will become a brick... and if you are having to many issues, role back to the national release version.
So please... you must absolutely understand these risks, before forcing this download
The Contents of the Release: (Differences based of Last National Release)
Items from CE:10:01
Items from CE:10:02
Items from CE:10:03
Items from CE:10:04
Items from CE:10:05
Improved
01 - Recording dependability
02 - DoD PgUp/PgDown consistent now
02 - Many MediaShare fixes
03 - Fix for certain video related issues
03 - Audio from video files
03 - VOD resume playback of partially downloaded program
03 - In the DoD Homepage, RED/GREEN will not lock up the STB when viewer is using a custom channel list that doesn't include the DoD channels.
03 - Remote Recording reliability
03 - Remote Recording properly handle cases where recording was already set
03 - 30 sec slip when at end of buffer
03 - Incorrect resolution display
04 - Misc fixes for reported issues
05 - Stability Fixes and Stability after Software Download
05 - Green key cycles audio tracks
05 - Faster signal meter
05 - Fixed frozen video frame
05 - Fixed CC characters from dropping
05 - Fixed review buffer from exceeding 90 minutes
05 - Support play from playlist while getting 771 message on ATSC channel
Updated
01 - Items in the DoD download queue, will remain after a system reboot
02 - MP3s supported
02 - HDTV is a searchable term (=High Def)
03 - Term "VOD" can be used in keyword search
03 - Red Button Delete disabled on Mark and Delete screen
04 - Updates to the UI (more about this after the CE rolls out)
04 - Mediashare ThumbNails improvements
05 - Added Winter welcome screen
05 - Fix resolution indicator in native mode
New feature(s)
01 - Triple Tap Lookup for DoD: When on a DoD page, you can use the # keys on your remote to enter letters in "cellphone/SMS" style. AKA: Hit #2 Three times to get a C
01 - Adult Channel Hiding: This is an update parental control that is currently on the R15. When you enable this, it completely REMOVES the adult rated channels from the listings, almost as if they don't exist.
01 - SLB Updates: Phase I - The live buffer should no longer EVER flush out for any other reason then changing the channel on the live buffer. Note the Phase I, they are planning more updates for the SLB
01 - IP Callback: The ethernet/internet connection, will now be used for communication back to DirecTV for: PPV purchases, GameLounge, and other items that the phone line was required for
01 - Mediashare Video Support: Phase I - You can now access video files from your PC. Note the Phase I, they are still working on additional codec's and full codec support; There is the possibility you will get video but no audio. This is a known issue, and will be worked on for future builds
01 - 30 Second Skip: You will now have the choice between 30s SKIP or SLIP. To enable: Keyword Search 30SKIP or 30SLIP
02 - Boolean Keyword searching, 3 new keywords AALL, AANY, NNOT
02 - 720p/1080i reminder pop up if TV supports but is in 480i/p and tune to HD channel
04 - Hitting Enter on a Full Screen, will display last 6 digits of receiver ID
04 - Guide: Channel Color shadding to represent subscribed vs unsubscribed channels
04 - Shortcut for Closed Caption On/Off
05 - Triple-tap 'enter' key moves to next letter
05 - SLB Updates: Phase II - Playback resumes from paused position on tuned channel
05 - Hitting SELECT on a Full Screen, will display receiver ID
Notes
Absolutely 100% make sure you understand the risks of this download; I want to see ZERO rants about any stability issues or noted issues/items above.
04 - This version still carries a high risk level
02 - Boolean keyword search examples: See this post
Note to other sites and users of those sites:
You are permitted to copy this CE Announcement in it's entirety (including this disclaimer) without modification so long as you provide a clickable link to DBSTalk.com.
Thanks Jimbo, im getting ready to start mine ;)
Goalie,
If you did the last CE, somehow it took away the Set Up or Settings menu, I didn't realize it till noqw when I need to get to the Reset section.
Did I just miss it, or is it gone from your too ?
I held the info button until it went to the sub menu tonight.
Jimbo
No its there. Its just more burried now. ITs under setup and settings. If I remember right its one of the last ones in the menu. I cant refer back now because im downloading the new CE right now :)
I am back up and running.
I am looking for the Help and Settings tab...
It use to be the first one when you pressed "Menu", now I cannot locate it.
I liked the old "Summer Software" vs the new "Winter settings"
Jimbo
It's now on the bottom of Menu grouped as Parental, Fav's & Setup. It took me a while to find it last week.
Gary
Goalie,
Jimbo
ISSUE: Searching for authorized content on HDPPV still there.
This is getting freaking annoying.
It's believed the software is nolonger at fault, but rather an issue with the transmission of the SAT signal missing the required authorization details.
There is a work-around for the HDPPV issue. Highlight and select the program from the guide, when the program info screen loads look for the $4.99 price in the upper right. If the price is listed the recording will work as expected, but if no price is visible this particular showing will not work. Most times at least one showing will have the correct details to function properly.
I know how to do the work around. The problem is it doesn't always work, or requires you to buy 1st record 2nd while you have to be infront of the dvr:smug.
Still having audio drop outs on ESPN I would imagine others as well.... this gets very annoying, particularly when showing it to others.
Jimbo
Music/Picture menu gone
Jimbo
Couldn't get my HR20-700 to download this version. Had no trouble with others up to this one. I tried several times on Friday and Saturday to no avail. After all the resetting and trying to do that I have lost the Music?Pictures from my menus. DOD/VOD still works fine but I have lost the Music/Picture on any menu's although my MediaPlayer 11 sees the HR 20 as does both my Laptop and Desktop. It working great until after I did all the stuff Friday and Saturday nights. I don't want to do another reset because I would be back at the National version instead of ox1D4.
Any ideas on how to recover the Music/Pictures? :confused:
bamakid
bamakid
I really have not gotten into the music/ pictures stuff, so I can't help too much in that area.
My TV also has a network ability so I may just see if I can get that working instead. It will handle all of the same things. When you can have a movie on the computer and play it on the TV in HD, then I will be more interested.
Others here can help you better on this one than I can !
Jimbo
Cutting Edge is not for Earl, Stuart, or DBStalk...
HR21-700 {CE:03:02} 0x192 Announcement
