Moving programs form 625 to 722..? | Page 2 | SatelliteGuys.US
Type in my previous post.. Meant to say ext3 not ext2..
Here's some shots clearly showing RAW partitions. The 461gb RAW partition obviously where movies would be stored.
622/722 using a disk divided to 4 partitons:
-- EXT3 data partition
-- EXT3 multimedia partition
-- SWAP partition
-- E*FS partition holding three internal partitions:
---> Misc
---> VOD
---> Recordings.
So how do you know that the E*FS partition has three internal partitions? How did you get access to it?
"Check Internet." You might as well say, check Yosemite. I have checked The Internet, as have others, and find no mention of such a beast. Really, obtuse comments may be fun for you in the know, but for those of us who are searching for answers, it's not too encouraging.
Well, PVRExplorer will allow one to extract programs from your 622/722, but it doesn't give any detailed "E*FS" partition info as you did. Not sure what "dishmod" is, and dishrip isn't compatible with these newer units.
Fifth 622 in four years
522 hard drive runs 24/7
