When they cut off the broadcast signal of analog tv, will it have any effect on Dish Network. Will my analog tv still work with my 722?
Actually, Dish's contracts may only apply to the current analog channel in many markets so what happens when those shut off ? Do they automatically switch to the digital channels ? Do we lose that local channel (if no new contract is agreed upon) ?Dish will still be able to supply locals, the shut off will not effect them as they will just be delivered to Dish differently is all.
Believed by whom? It doesn't take very long to replace an analog tuner with a digital tuner.It is believed that many of these analog backhaul feeds will not be converted to digital in time for the 2009 analog shutoff.
He is referring to a Dish and Directv claim from a month or two ago and rest assured, changes at the local channel's uplink facilities involves FAR MORE than just swapping a tuner out !Believed by whom? It doesn't take very long to replace an analog tuner with a digital tuner.
Because D* and E* share a lot of the backhauls, they'll be collectively motivated to see that the necessary changes are made.
As long as you have an OTA antenna on your model 622 or 722 receiver and can receive your local digital channels you will not be affected at all.
Memo to skottey:Dish 722 boxes will cease to work when OTA analog broadcasting ends in 2009.
Memo to skottey:
- The 722 does not pick up OTA analog
- The 722 does pick up OTA digital
Any customers with a 622 or 722 and an antenna that picks up their local digital channels will be just fine.
- OTA digital broadcasts will continue after Feb 2009, analog will not
You would lose your tv guide for locals, if you lose the locals. The 722 is useless without the tv guide. Dish had better see that they get the locals converted to digital, (not necessarily HD) before the conversion date.
wow.... you really have no sense of sarcasm do you? Please re-read my reply... I was, um, being sarcastic.![]()
Sorry, but you gave NO indication that it was sarcasm.... A smiley would have done the trick.![]()
Limited time offer
