Directv 10 Channel to Transponder Mappings | SatelliteGuys.US
TheSpecialist
10
Attached is a list of the new HD channels and what transponder on D10 they reside on.
***Updated 10/18/2007*** 7:15Eastern
Could the shaddow in the night make this a regular thing when we get updated new channels? For example some of the recent RSN launches are not on there like 636 that went live Monday.
This will be a nice resource though if you have breakups on a particular channel or something.
I have several transponders in the 95 range, but a few in the 70 range that I want to keep an eye on to see if I need to repeak.
Take a look at transponder 6 & 11 - 5 channels.
At first I thought they would turn off the PPV for RSNs like E* is doing, but the RSNs on these transponders are up 24/7.
I guess those new encoders can do more than 4.
The new harmonic encoders supposidly can do 6, allthough I dont think that is in full rez mode. Unless directv has found another MPEG4 vender that can do better. Thanks to the OP who posted that file. Its kind of crazy how much were growing here and the info we get :)
There are so few companies making HD h.264 encoder/stat muxes that I would be surprised if Dish/Direct aren't using the same equipment. The only difference right now is the modulation used on the transponder. I'm sure if Direct could get a higher bitrate on their TPs we'd see more channels crammed on each.
Channel map updated. Please let me know if I have missed a channel. Future update will include native resolution of channel (not transmitted res).
Have been playing around with the information we have so far.
103(b) has 16 active transponders.
At four channels per transponder you get very high quality HD and 64 channels.
At five channels per transponder you get quality HD and 80 channels.
At six channels per transponder I'm sure this may have an impact on the overall image quality they can have 96 channels.
Add in four mpeg2 two channels from 119 and you get the magic number promised this year of 100.
They will need to get D11 up to maintain the quality and further the HD expansion.
Matt
Pull up 103(b) and count the numbers you get, They add up to 16 with the last number being on transponder number 22.
Matt
Maybe not all the transponders are active right now. I thought that D10 had 32 transponders.
Hope you are correct about bringing able to turn on more transponders the HD feeds/count could go way up !
Matt
Other transponders maybe spot beams. Read somewhere D10 had some and trouble with north west area USA ones.
If someone can do the math, D10 broadcasts a total of 500 MHz.
Whether all of this is CONUS is not known (by me anyway).
Question: Are the transponder sizes on Ka-band necessarily the same as the sizes on Ku-band?
DirecTV 10, 11 & 12 (ground spare) are all listed as Boeing 702's (BSS-702)
Equipment: 32 (+12 backups) Ka-band transponders, 55 (+15 backups) Ka-band Spot-Beam transponders
Configuration: BSS-702
Propulsion: R-4D + 4 XIPS
Lifetime: 15 years
Mass: 5893 kg (#10) (3700 kg dry)
Best OTA solution
Trouble with MPEG4 channels
