HR20-700 / Oct. 12 & 13 / ?? | SatelliteGuys.US
Brewer4
4,022
Hartford Connecticut
Per Earl at DBSTalk.Com
As of this morning:
HR20-700 : 75% chance
H20-600: 20% chance
No other CE's expected this weekend at this time.
Confirmation and release notes to come later today.
So at what time will I be able to download the latest CE version which includes DOD?
Thanks,
Mark
does anyone know if this release enables dod? I tried the IWANTMYVOD keyword search searching for all and it found nothing.
ok i have the on demand menu available. When I click it though nothing happens, is this normal?
Posted by Earl Bonovich from DBSTalk.com
Systems in this CE / Version
HR20-700 {CE:09:08} - 0x1AF
Windows of opportunity to download:
Friday; October 12, 2007 11PM - 2:30AM ET
Saturday; October 13, 2007 11PM - 2:30AM ET
Download Probability: 85%
Be sure to monitor the threads and chat room to check on final availability
The Contents of the Release: (Differences based of 0x18a National Release)
  • Items from CE:09:01
  • Items from CE:09:02
  • Items from CE:09:03
  • Items from CE:09:04
  • Items from CE:09:05
  • Items from CE:09:05a
  • Items from CE:09:06
  • Items from CE:09:07
  • Items from CE:09:08
Improved
  • Prioritizer Screen
  • Navigation to PIG (Picture In Graphics) removed. (Trick Play Still works), to improve interfacing with UI
  • Stability
  • Several user interface polishing and fixes based on CE reports
  • DoD: Misc. Reported issues fixed
  • DoD: Performance improvement
  • User interface polishing
  • DoD UI: Restored CHANNEL UP/DOWN in the Homepage Left Menu.
  • DoD UI: Homepage "tuning" fix for consistent prevs channel
  • DoD UI: Added "On Demand" to quick menu after "My Playlist"
  • DoD UI: UI Polishing/fixes
  • Caller ID (no specifics on what)
  • UPnP issue that certain networked Cameras could crash the box.
  • A plethora of fixes to issues identifed in the previous CE's
  • Several UI Fixed and Polishing
  • Fixed the CE Introduced issue with items in the ToDo List, but ultimately not recording
  • DoD UI: "More VOD" in ever page
  • DoD UI: Misc. Items
  • DoD: Corrected - Not being able to resume playback of a currently downloaded program
  • DoD: Corrected - Listing performance
  • Additional Stability fixes
  • Missed recordings
  • Tuning issues
  • Channel info not updating with record icon
  • Channel banner issues
  • Active main page loosing highlight
  • DoD: Deleting active DoD item from Playlist taking long time
  • DoD: Unable to delete program if it was paused on the queue
  • DoD: Fix guide paging down when graphic row appears
  • Improved interactive load time
  • Improved remote control accuracy
Updated
  • History list now includes conflicting program
  • Unwatchable content is no longer kept in the disk
  • Exiting FF via RW or PAUSE then Play, will no longer AutoCorrect
  • Modem will drop connection when phone is phone is picked up
  • AutoCorrect FF will not "correct" when STOP or REPLAY is pressed
New feature(s)
  • Keyword search finds category (eg HDTV or sports)
  • [strike]Caller ID for Type 2 (aka Call Waiting, off-hook, ect); Caller id reverted to 0x18a version[/strike]
  • Start/resume to manual
  • Left arrow mimics "BACK" when practical
  • Long channel name in search by channel
  • Ability to hide SD channels if duplicate HD channel with same number exists
  • Support for Remote Booking
  • DoD: Pressing INFO when over the DoD channel goes directly to the "ALL" List
  • Grouping of Search Results
Notes
  • There are other misc. updates in the release
  • GUIDE DATA WILL NOT BE CACHED they are enhancing pieces of the guide data, which means you WILL LOSE your guide data after the install. It will repopulate over the next 20-24 hours.
    This is only valid if you are comming from 0x18a, if you are on 0x19* you are not expected to lose your guide cache
  • DoD GUIDE DATA will most likely be lost after you reboot the system.
  • This is the eighth CE in the cycle... So the risk level is lower then the previous ones, but there is still a risk involved. Please only download this CE release if you are willing to take that risk
  • This will be primarily an issue correction release, new features are not expected
Note to other sites and users of those sites:
You are permitted to copy this CE Announcement in it's entirety (including this disclaimer) without modification so long as you provide a clickable link to DBSTalk.com.
HR20-700 0x18a
CE?
I never tried a forced download because I always seem to forget or miss the window.
What exactly do I need to do after 11:00 tonight?
I tonights download works for me do I then need to do the "IWANTMYVOD" keyword search"
In my system info future upgrade says "Not Scheduled"..Is that normal?
HR20-700 0x18a
CE?
During the window you can download the software using the proceedure below. The keyword search is needed to enable VOD. Also the future upgrade shows "Not Scheduled" until DIRECTV pushes an upgrade.
1. How to Force Download a Cutting Edge (CE) Release
2. How to Activate DIRECTV on Demand with HR20-700
HR20-700 0x18a
CE?
Read this:
http://www.satelliteguys.us/directv...read-first-cutting-edge-risks-guidelines.html
This:
http://www.satelliteguys.us/directv...w-force-download-cutting-edge-ce-release.html
This:
http://www.satelliteguys.us/directv...6-how-activate-directv-demand-hr20-700-a.html
And finally this:
http://www.satelliteguys.us/directv...ing-csr-tier-regards-anything-ce-related.html
Or just look at the stucky threads at the top of the forum
Hr20-100......
H20-600 / Oct. 12 & 13 / {CE:08:06} - 0x2040
