Thanks guys..
What chip set does the Colby use..
Guess there isn't any such thing as a cheapo HDTV tuner..
That coby unit, priced at under $100 is about as cheap as I have ever seen a tuner for.
The myth that there will be a tuner for under $50 by 2009 is just that, a myth, as far as I can see.
Ever heard of a hisense db-2010 (us digital service box)
They have a really nice pip guide and have a strong tuner that pulls in signals well. Ck on ebay for examples - good prices also. Very good as a 2nd tuner/backup or to update a standard tv w/o atsc tuner.
no hdmi tho. Ck it out and tell us what u think about them.
tonare1
I have these in stock! a+ product! you will not be dissapointed. composite out, component out, digital audio, usb, s-video out, right /left audio out, remote control, global scan and channel freq scan!! $50 fob, used. The best I've seen yet!! restart on channel after a power cycle for you "mdu" guys!!
I have the GS 1100 antenna, works great fr digital tv, $16 each fob,new
......Do all outputs pass the signal at once..(no, 1 composite and 4 hdtv settings, menu selectable) If you're using the OTA tuner does the antenna signal still pass through to your TV, (no, use a splitter, you'll need it! I use a 6 antenuator to lower the signal, the tuner is very low threshold! ) .. Can the manual be downloaded on-line.. (not by me, more fun....NO BOOK! you get to "ride all the rides" with no book!!)
What is fob.. "freight on buyer, fob)
Thanks, Brent
No manual? Company out of business? No support? No warranty? Seller trolls forums to sell them? What could be more fun?
BTW, "FOB" mean "freight on board" or simply "plus delivery charges." Not sure where you got your definition, but check again.
Limited time offer
