622 Buffer question - Am I missing something? | SatelliteGuys.US
adavis720
253
Ok here is the situation -
I am watching a show on Satellite tuner A. I watch a DVR event, and then end it, going back to the Satellite tuner A. At this point I feel like I should be able to rewind. Why is it not possible?
If I swap, I can rewind on that channel but it always seems like it swaps to the OTA tuner. Is it ever possible to swap from Sat tuner A to Sat tuner B with recording something on either of the Sat tuners?
Am I missing something here?
I am in Single mode, BTW.
Poking around in the prefs, in "Record Plus", everything is greyed out, since I am in Single mode and in Setup -> Shared View is enabled, but that shouldn't have anything to do with this.
Incidentally, in "Record Plus", what is the deal with ERD setup? Does that actually work now? I enabled it just for fun.
Because the "current" tuner is not buffered when you are watching a DVR event.
ERD is for setting up timer recordings to the POCKETDISH
Ok, thanks.
I will just swap away from the tuner I want to be active after the DVR event.
Sort of counter-intuitive...
Break off 129 to seperate Dish
NHL Center Ice HD Question?
