625: Only 1 tuner passes DD5.1? | SatelliteGuys.US
DishSubLA
5,450
1,418
Dear friends,
While at my uncle's I was having to reset things for his new mega-big Sony LCD and his home theater. Then I came across something very strange with his 625: While in single mode I noticed that if both tuners are tuned to the very same channel , for this example, Showtime East, one tuner passes the DD5.1, but when it is swapped to the other tuner, it passes audio that results in Dolby Pro Logic--NOT DD5.1. Keep in mind the audio system does NOT change, only the tuner (single mode swap and when manually changed to the channel) outputting to the sound system. I conducted the experiment several times and confirmed this.
Has anyone heard of this? Can someone experiment and confirm this. It happened about 2 weeks ago, perhaps it works properly by now. Any enlightenment on this would be much appreciated.
Thanks.
I have the 625, but I use it in dual mode..........only tuner 1 passes the DD 5.1 signal. Or should I say passed.........for the past several weeks, I have not been able to find anything on Showtime or Starz that is being broadcast in DD 5.1 according to the program guide.
Program Upgrade
722 has DD Optical Audio Dropouts
