O oao New Member Original poster Sep 19, 2007 3 0 Sep 19, 2007 #1 I need to know if I can get Galaxy 25 and Galaxy 26 on the same dish ( 1 meter with 2 LNBs).
scottc98 SatelliteGuys Pro Feb 28, 2006 1,342 0 Columbus, OH Sep 19, 2007 #2 4 deg seperation.....yeah it will work. Look at SatAV's webpage (SPONSOR). they have an adapter for their 'bullet' lnbs that should work for you.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,378 14,852 Mankato, MN Sep 19, 2007 #3 The adapter only works for their 76cm & 90cm dish. It wont work with others due to the focal point
scottc98 SatelliteGuys Pro Feb 28, 2006 1,342 0 Columbus, OH Sep 19, 2007 #4 My bad.....either way, I'm sure that 4 deg is possible. If they can do it on a 76cm, he can do it on a meter
Anole SatelliteGuys Master Sep 22, 2005 11,819 14 L.A., Calif. Sep 20, 2007 #5 If you are looking for some examples or some encouragement, try reading these three threads. Linuxman has really been busy with two LNBs per dish, lately. Of course, many other members have, too. Some with three or four satellites per dish. http://www.satelliteguys.us/free-air-fta-discussion/97742-123w-129w-1-meter-primestar.html http://www.satelliteguys.us/free-air-fta-discussion/99108-87w-97w-primestar-84e-multi-lnbf.html http://www.satelliteguys.us/free-air-fta-discussion/100714-how-1-meter-primestar-g10-ku-123w.html The forum is just littered with examples.
MrTim SatelliteGuys Family Sep 21, 2004 87 0 Atlanta, Georgia Sep 21, 2007 #6 Take a look at http://www.dmsiusa.com/g25-g26.htm for more ideas. Hope it helps you.
Anole SatelliteGuys Master Sep 22, 2005 11,819 14 L.A., Calif. Sep 21, 2007 #7 Nice work, Tim. - :up The more such sets of pictures you have (and make easy to find), the better!
O oao New Member Original poster Sep 19, 2007 3 0 Sep 21, 2007 #8 Thanks all for the advise. Your Guys are great. I'll try and let you know. One more info. I forget to add that I'm located in Toronto Canada and as far as I know from the people that can see Galaxy 25 and 26 that they have big dish (33 in or more).
O oao New Member Original poster Sep 19, 2007 3 0 Sep 29, 2007 #9 Thanks for the great advise. It works. Now I can get galaxy 25 and 26 on the same dish (1meter). Other people get also on 33'' dish.
aegrotatio SatelliteGuys Pro Jan 23, 2006 350 2 A Public Bathroom Sep 30, 2007 #10 Iceberg said: The adapter only works for their 76cm & 90cm dish. It wont work with others due to the focal point Click to expand... Sorry to disagree, it works on my Winegard 76cm.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,378 14,852 Mankato, MN Sep 30, 2007 #11 aegrotatio said: Sorry to disagree, it works on my Winegard 76cm. Click to expand... thats cool. I was told it only worked on those dishes
