My guess:Fixes:
EHD, Signal, CSA, Reboot fix, EPG Fav
My guess:
EPG Fav - remove annoying message hopefully !
No, they moved it up so you now always have the date/time.
I'm eager to hear how this version affects Seagate drives.
For that matter I've had my HDMI go out as well. :/
They didn't fix the reboot issue on my 622. I am on my second receiver and now getting a third because of a looping reboot every 5 minutes or so. Really frustrating. Spent 4 days on the phone with TS to finally hear from them that it is a software problem.
A small but annoying bug has appeared with L443 that was not present in L441.
With L441, my HomePlug/DishCOMM broadband connection seemed to work without any errors. I wish I could say whether or not the phone icon on the top right of the Info screen (Menu 6-1-3) was green or yellow, but I don't recall. It is possible that it was yellow and the system was not producing the 588 error dialog box.
Either way, with L443 I now get the 588 error dialog box that informs me I need to have my phone line or ethernet connected in order to avoid the $5 fee. The Info screen shows the phone icon as yellow with a red slash. Dish support told me that this icon applies to either phone or broadband connections despite having a telephone handset as the icon. Because of the introduction of broadband support I pulled my wireless phone adapter; going back is not as easy an option as one would think due to my configuration.
I have reset the broadband connection, reset the router, and reset the ViP622. None of these has removed the issue with 588 error appearing.
Either L443 broke the ability to detect broadband connections or it was always broken but the error dialog did not appear until L441. I'm pretty skeptical that it was always broken after reviewing my router activity logs...
I've read where others are seeing this error but have not seen any discussion about trying to isolate the cause.
Red
Limited time offer
