Antenna In on H20 | SatelliteGuys.US
Antenna In on H20
jhilley
15
What good is the Antenna In connector on the H20, there isn't an RF out connector?
Well if you don't have HD locals in your area thru D* then you can get your locals in HD via OTA. If I am not mistaken there should be a RF on the H20. Doesn't your have a small antenna like thing on the back?
Your OTA signal also allows your OTA guide to show up in the D* guide, this is a great feature, the older receivers did not allow this.
cgking,
The small RF connector on the back is for an RF antenna, the remote works IR and RF.
Jimbo
The H20 is an HDTV receiver your outputs for HDTV are component or HDMI coax dosen't carry HDTV except when going to an ATSC tuner.
cgking,
Jimbo
Not all remotes, Jimbo. The RC 32 isn't an rf remote.
Thanks, it must be for the OTA Guide. This H20 does have the RF antenna for the remote.
HR20 freezes when viewing live feed
Sports Time Ohio HD?
