Your G-19 Signal Report is Needed | SatelliteGuys.US
SatelliteAV
6,486
186
Roseville, CA
We need your assistance to determine the Signal Strength and Quality of a new transponder started 3/2/2010 on Galaxy19, 97W. Before we begin to relocate current viewers from AMC4 to the new frequencies on Galaxy19, we need to report to the broadcasters on the transponder performance. TRansponder testing and adjustments can be made at this time if performance issues are reported. We will only need comparison Signal Quality readings for your location as each receiver will provide a different SQ reading.
If you are on the edges of the footprint in Northern Canada, Alaska, Hawaii, Southern Mexico and the Caribbean, we especially need to receive reports from your locations.
Please indicate the size of your dish and your location and report on the frequencies below:
11789 V 28125 - SQ:
11836 V 20765 - SQ:
11842 H 22000 (new) - SQ:
11867 V 22000 - SQ:
11874 H 22000 - SQ:
11936 H 20000 - SQ:
11966 H 22000 - SQ:
12053 V 22000 - SQ:
12060 H 22000 - SQ:
12115 V 22425 - SQ:
12177 V 23000 - SQ:
Thank you for your test results and taking the time to provide valuable assistance for qualifying this new transponder!
Southwest MO, Clear and cold
Fortec 90 cm, Coolsat 6000 (1.04 fw), Inv. Quad LNBF
11789 V 28125 - SQ: 75%
11836 V 20765 - SQ: 73%
11842 H 22000 - SQ: 72-75% (bouncing)
11867 V 22000 - SQ: 76%
11874 H 22000 - SQ: 76-79%
11936 H 20000 - SQ: 79%
11966 H 22000 - SQ: 76%
12053 V 22000 - SQ: 78%
12060 H 22000 - SQ: 79%
12115 V 22425 - SQ: 72-75%
12177 V 23000 - SQ: 76%
South Eastern Wisconsin Milwaukee/Madison Sunny and Cold around 27 'F today
WSI 90cm, Inv Quad LNBF N-fusion HD
11789 SQ 70%
11836 SQ 55-60%
11842 SQ 45%
11867 SQ 70%
11874 SQ 52%
11936 SQ 50%
11966 SQ 60%
12053 SQ 82%
12060 SQ 70%
12115 SQ 68%
12177 SQ 80%
I do need to get up on the roof and put up a new motor and do a repoint.
Northwestern Lower Michigan, Clear and 29 degrees.
1.2m GeosatPro Dish, Invacom quad lnbf, Sonicview Elite
11789 V 28125 - SQ:90
11836 V 20765 - SQ:42
11842 H 22000 (new) - SQ:96
11867 V 22000 - SQ:49
11874 H 22000 - SQ:94
11936 H 20000 - SQ:50
11966 H 22000 - SQ:98
12053 V 22000 - SQ:93
12060 H 22000 - SQ:98
12115 V 22425 - SQ:47
12177 V 23000 - SQ:80-84
39.7°N 76.8°W Mason/Dixon line north central MD Using Coolsat 5000
11789 V 28125 - SQ: 87%
11836 V 20765 - SQ: 88%
11842 H 22000 - SQ: 88%
11867 V 22000 - SQ: 89%
11874 H 22000 - SQ: 90%
11936 H 20000 - SQ: 90%
11966 H 22000 - SQ: 92%
12053 V 22000 - SQ: 93%
12060 H 22000 - SQ: 93%
12115 V 22425 - SQ: 94%
12177 V 23000 - SQ: 93%
Interesting request and glad to help (if my help is useful)
33" motorized dish, not sure of the manufacturer, I got it five years ago, invacom quad, coolsat 5000, 55 degrees and NO wind today, Mohave County, North West AZ (Between Kingman and Bullhead City). Listening now to you being interviewed on Satguys Radio replay, so I may as well also admit to being about 100 miles North of Lake Havasu City (smile). I mention that because there is an interview with someone from a radio station in LHC.
11789 v 28125 sq: 69%
11836 v 20765 sq: 70%
11842 h 22000 sq: 63% locked with two channels, tv Eng and tv Latino
11867 v 22000 sq: 72%
11874 h 22000 sq: 70%
11936 h 20000 sq: 64%
11966 h 22000 sq: 65%
12053 v 22000 sq: 75%
12060 h 22000 sq: 70%
12115 v 22425 sq: 72%
12177 v 23000 sq: 72%
Photto
glorystar g19 transponder signal quality
Glorystar,
90cm standard (dual-lnb) ; St Louis, Mo ; 2 receivers
#1 receiver: DVR-1100c -- #2 receiver: Fortec Star Mercury II
11789 V 28125 - SQ: 1 - 79%; 2 - 55%
11836 V 20765 - SQ: 1 - 66% ; 2 - 53%
11842 H 22000 new - SQ: 1 - 74% ; 2 - 48%
11867 V 22000 - SQ: 1 - 75% ; 2 - 54%
11874 H 22000 - SQ: 1 - 56% ; 2 - 76%
11936 H 20000 - SQ: 1 - 75% ; 2 - 56%
11966 H 22000 - SQ: 1 - 73% ; 2 - 46%
12053 V 22000 - SQ: 1 - 86% ; 2 - 62%
12060 H 22000 - SQ: 1 - 82% ; 2 - 55%
12115 V 22425 - SQ: 1 - 69% ; 2 - 44%
12177 V 23000 - SQ: 1 - 75% ; 2 - 46%
30" dish, central Pennsylvania, overcast
11789 V 28125 - SQ: 73
11836 V 20765 - SQ: 70
11842 H 22000 (new) - SQ: 71
11867 V 22000 - SQ: 72
11874 H 22000 - SQ: 71
11936 H 20000 - SQ: 71
11966 H 22000 - SQ: 71
12053 V 22000 - SQ: 74
12060 H 22000 - SQ: 73
12115 V 22425 - SQ: 71
12177 V 23000 - SQ: 73
SouthEast ON, Partly cloudy, +5 C
1 m Dish, , Invacom LNBF
.......................Coolsat 5000 and AzBox
11789 V 28125 - SQ: 94% -- 72%
11836 V 20765 - SQ: 88% -- 60%
11842 H 22000 - SQ: 90% -- 73%
11867 V 22000 - SQ: 91% -- 71%
11874 H 22000 - SQ: 91% --72%
11936 H 20000 - SQ: 91% -- 73%
11966 H 22000 - SQ: 92% -- 78%
12053 V 22000 - SQ: 94% -- 78%
12060 H 22000 - SQ: 92% -- 75%
12115 V 22425 - SQ: 90% -- 64%
12177 V 23000 - SQ: 90% -- 71%
Northern NY, sunny, mid 30's, 90CM CM dish, SG2100 motor, Hughes c120 lnb, Fortec Star MercuryII.
11789 V 28125 - SQ: 55%
11836 V 20765 - SQ: 55%
11842 H 22000 (new) - SQ: 50%
11867 V 22000 - SQ: 50%
11874 H 22000 - SQ: 50%
11936 H 20000 - SQ: 46%
11966 H 22000 - SQ: 43% - I can't ever seem to get this one w/o pixelation. Could River move? (hint, hint)
12053 V 22000 - SQ: 65%
12060 H 22000 - SQ: 58%
12115 V 22425 - SQ: 53%
12177 V 23000 - SQ: 59%
Anything below 45% is generally not watchable for me. The only exception I can recall was WhiteSprings which came in good with 30-35% SQ.
11789 V 28125 - SQ: 49%
11836 V 20765 - SQ: 50%
11842 H 22000 - SQ: 25%
11867 V 22000 - SQ: 49%
11874 H 22000 - SQ: 25%
11936 H 20000 - SQ: 35%
11966 H 22000 - SQ: 37%
12053 V 22000 - SQ: 60%
12060 H 22000 - SQ: 47%
12115 V 22425 - SQ: 49%
12177 V 23000 - SQ: 49%
33 inch dish, SG2100 with JSC321-S LNB Viewsat 2000 Ultra
Southwest Oregon 123w 42.1n
Los Angeles, 1.2 Meter, Coolsat 6000
11836 V 20765 - SQ: 90
11842 H 22000 (new) - SQ: 94
11867 V 22000 - SQ: 92
11936 H 20000 - SQ: 94
11966 H 22000 - SQ: 90
12053 V 22000 - SQ: 91
12060 H 22000 - SQ: 90
12177 V 23000 - SQ: 88
Northern Mexico, 150 miles south of Texas border, sunny
Pansat 2700, 30" dish
11789 V 28125 - SQ: 49 - 55 bouncing
11842 H 22000 (new) - SQ: 55
11867 V 22000 - SQ: 55
11874 H 22000 - SQ: 55
11936 H 20000 - SQ: 55
11966 H 22000 - SQ: 40
12053 V 22000 - SQ: 70
12060 H 22000 - SQ: 70
12115 V 22425 - SQ: 41
12177 V 23000 - SQ 55
Here goes: 11789 V 28125 - SQ:30 11836 V 20765 - SQ:17 11842 H 22000 (new) - SQ: 30 11867 V 22000 - SQ:29 11874 H 22000 - SQ:38 11936 H 20000 - SQ:43 11966 H 22000 - SQ:36 12053 V 22000 - SQ:26 12060 H 22000 - SQ:44 12115 V 22425 - SQ:19 12177 V 23000 - SQ:40 Location: Midwestern Ontario, Canada Dish: 75CM nearly round, I think primed at 89 or 91W (the one the The Patient Channel), with 97 on a side LNBF, so the signals are not as good as they could be.
East Central Florida, clouded, mid 50's, windy 20mph, 36in, 90CM CM Fortec dish, SG2100 motor, Fortec Classic
11789 V 28125 - SQ: 66%
11836 V 20765 - SQ: 66%
11842 H 22000 - SQ: 60%
11867 V 22000 - SQ: 66%
11874 H 22000 - SQ: 60%
11936 H 20000 - SQ: 60%
11966 H 22000 - SQ: 55%
12053 V 22000 - SQ: 80%
12060 H 22000 - SQ: 66%
12115 V 22425 - SQ: 66%
12177 V 23000 - SQ: 66%
I hope it helps
Receiver: Coolsat 6000 Premium
Dish: 10 Ft Mesh
note: I get better signal at night (about a 10% bump) but all these TPs are coming in fine right now, except for 12115V and 12177H which are weak at this moment
11789 V 28125 - SQ: 69%
11842 H 22000 (new) - SQ: 69%
11874 H 22000 - SQ: 67%
11936 H 20000 - SQ: 69%
11966 H 22000 - SQ: 69%
12060 H 22000 - SQ: 67%
12115 V 22425 - SQ: 63% (Weak, stronger signal at night)
12177 V 23000 - SQ: 63% (Weak, stronger signal at night)
Suburban Minneapolis, MN
36" GeosatPro dish
WSI dual LNB (the orange one)
GeoSatpro DSR200
11789 V 28125 - SQ:75
11836 V 20765 - SQ:65
11842 H 22000 (new) - SQ:70
11867 V 22000 - SQ:75
11874 H 22000 - SQ:70
11936 H 20000 - SQ:70
11966 H 22000 - SQ:70
12053 V 22000 - SQ:80
12060 H 22000 - SQ:80
12115 V 22425 - SQ:70
12177 V 23000 - SQ:75
90 CM, Canby Oregon
11789 V 28125 - SQ:62%
11836 V 20765 - SQ:60%
11842 H 22000 (new) - SQ:60%
11867 V 22000 - SQ:49%
11874 H 22000 - SQ:62%
11936 H 20000 - SQ:50%
11966 H 22000 - SQ:40%
12053 V 22000 - SQ:70%
12060 H 22000 - SQ:68%
12115 V 22425 - SQ:51%
12177 V 23000 - SQ:68%
Recent Acquisition. Spring Project?
nbc sat mux 3 & 4 audio?
