You Tube Gone Again as of Aug. 4th. | SatelliteGuys.US
stargaze
916
56
Out there somewhere
You Tube is down once again on the AzBox.
The old patch to fix it for older firmware no longer works either with the latest change they made.
Look for a new update to fix this soon.
Something is up on the you tube site as you are not abled to download music from the site with youtubeget either and I am using the latest version 5.9.4 so it may not be an azbox issue at present.
Very surprising that after 5 days a fix hasn't been posted yet on AzBox Snapshots. Guess YouTube isn't considered to be a priority.
We are aware of the issue and are working on it. Youtube just changed the way they handle filters so most non-web Youtube applications are affected. The filter logic in the application needs to be adjusted in order to work with the new way that Youtube is now handling filters.
Regards,
PwrSurge
AzBox Canada
Flickering Video
WIFI ISSUES WITH LATEST SOFTWARE
