Anyone able to get this Channel..,, it is listed both at Lyngsat and global-cm.net, but I have blind scanned and scan 12140 V for it... no luck.
mastermesh said:and then go in to edit tp in the bird in your reciever and enter the tp and sr if the tp/sr combo is not already loaded in the receiver, then blind scan that tp or just blind scan the whole bird again. I'm seeing a lot of tps on lyngsat (especially feeds) that weren't in my 3500sd's presets... so this weekend I'm probably going to manually go to lyngsat, print off all the birds' pages and manually enter tp/sr and polarity info... did that this mornong on amc3 I think, and suddenly pulled in a LOT more channels... (good portion of which were news feeds).
When your receiver blind scans it only blind scans the tps that are in it's memory. if the channel you are looking for is not in memory of the receiver, your dish can be looking right at the satellite all day and you can do 3 million and one blind scans, but you'll never see the channel you are after... sort of like trying to use AM radio tuner to find an FM station.
True, the whole advantage of blind scan is to find new TPs that aren't programmed into the receiver (i.e., feeds that come and go)...digiblur said:Sounds like someone isn't using a real blind scan???
I can delete every TP on a bird on my Fortec and hit blind scan. The TP's are automatically saved and scanned. This is a real blindscan...
Same here, my Fortec Lifetime Classic NA never found it with blind scan either. After the first post in this thread I blind scanned the sat again with both the default 6 scan step and a 4 step. Neither one found this transponder. Once I manually added the transponder it found the channel immediately.W_Tracy_Parnell said:Never laid eyes on this channel before, blind scan on the Coolsat wouldn't pick it up. Did a manual scan on 12140 v 2222 and it came right in!
I wonder if it has something to do with the level? I have a Fortec NA and it scanned right in using blind scan. I running at between 55 and 60 percent.hwh said:Same here, my Fortec Lifetime Classic NA never found it with blind scan either. After the first post in this thread I blind scanned the sat again with both the default 6 scan step and a 4 step. Neither one found this transponder. Once I manually added the transponder it found the channel immediately.
Maybe, mine is a little lower, a solid 46 with occasional jumps to 53-55. However, other sats I've scanned have found transponders way lower than that.123tim said:I wonder if it has something to do with the level? I have a Fortec NA and it scanned right in using blind scan. I running at between 55 and 60 percent.
Limited time offer
