Wiring suggestion (522/backfeed/antenae) | SatelliteGuys.US
swicked
Pennsylvania
I have a dual LND dish (DP plus) 2 lines in.
the one line i have run to my 522 dual tuner receiver and backfed to hit another TV.
Then the 2nd line in goes straight to a single tuner.
I also have an antenae I'd like to use to hit each tv.
What i want to do is only run 2 wire to my 522 and combine/separate/backfeed it - rather then run 2 seperate lines like when i used the DP 34.
Any help/suggestions would be appreciated
THANKS
since you now have a plus lnb you could get away with one cable using a dp separator and 2 diplexers.
if you are happy with 2 coax's just use one to feed tv2 and run one line from your dpp lnb and use the separator, it should have been included with your 522.
GL
Cheapest plan for someone who just wants nba league pass
Best way to hook my 722 up to the internet?
