Wiring for AT&T U-Vurse???? | SatelliteGuys.US
blockisle9
217
I just ordered AT&T U-Vurse, Its free install, but I want to pre- wire it my self (Being an Electrition)
I have two TVs and two PC,s one hard wired and one wireless hooked up to DSL.
If I run a seperate Cat 5-e cable to each tv and the PC from a central location in the basment and another Cat5-e cable from that basment location to the outside of the house where the phone wire comes off the pole, is that the best way to do it? Or should I use RG6 coaxal cable or a comination of both?
Any advice will be great...........
Lenny
I don't have Uverse (not avail). I spend a lot of time at the uverseusers.com, and the folks over there say Cat5 from the RG to the set top boxes. You can use RG6, but there have been more problems than not with it. Not sure what to run from the RG to the NID. Give thier site a try. Try later though, because it's down right now. Good luck.
What Is The Correct Setup?
