wiring diagram | SatelliteGuys.US
wiring diagram
Well the easiest way is if you have cable wiring in the house. Just be sure the cable wiring is disconnected from the cable system. You can then feed the RF output from each of the receivers through the cable system (just be sure they are set to transmit on different channels). Then 2 of your TVs get the output from the receiver, and the other 3 share the 2 outputs from the receivers.
time for deregulation?
BHN Adds new channels to sports pack
