Wireless Question | SatelliteGuys.US
Wireless Question
DetFan
2,029
121
Livonia, Michigan
Anyone that can help that would be great Im bayond frustration.
Just bought a TIVO Series 2 and have no phone line. I cannot figure out what will work with my wireless network. Its a Lynksys set up currently set on G, but I can change it to B if need be.
No, my question was which one Could I use that list is a little decieving.
Can i use something other then a Linksys?
Inside a typical network, YES, as far as perfect compatibility with TiVo you can only test it out if its not on that pre-tested list, but there should be no reason why it shouldn't.
Thanks for your help.
Im in the process of setting it up now, I have not gotten my adapter yet so I have thie rigged up set up using my old voip line I never disconnect, and running it through my fax machine, so far IVe gotten the channels set up, but it is spotty at best because of the disconnects..Grrr, this is frustrating. I cant leave yet until the wife gets home, or drag the kids to get one, and that is not happening.:devil:
[CABLEVISION] Recording
My HD .WMV movie!
