Wireless Phone Jacks | SatelliteGuys.US
JTDeel
13
I 've read all the post reguarding this topic but my question is what all do I need to hook up 2 recvr's and dsl if it is possible.
TIA
JT
You want to make sure you get wireless MODEM jacks. Regular wireless phone jacks might not work. You can get the base unit that comes with one extension and then get extra extensions. Not sure how it would work for DSL though. I got mine at Circuit City for $40 and it works great.
Mike
if you get two or one each (vip622 and vip211) are supposed to have built in wireless phone jacks. you plug a phone in only one and the receivers talk to one another. they are so far the only receivers on the market that do this.
I don't think they have activated the feature where only one of the ViP622/211 needs a phone line.
DSL will require a wireline to your provider. You can plug in a wireless router, if you wish.
No signal on TP 22 Sat 110
What are my options (got 211 need 622)
