I'm camping and trying to hook up my winegard pm-2000 dish to my directv r22. I called directv and they didn't help me. I set the elevation and azimuth but I'm still getting no signal. Any help?
My first thoughts are that you aren't level(plum) with the dish so your settings won't matter. If you are indeed level, then confirm you have the settings accurate and your cable is in good order.
Your limited info leads me to believe that you have a clear view in the direction that you need to point? If all of these things are true and you are indeed doing them, then more info about your setup may be needed.
