Winegard MP1 portable dish questions | SatelliteGuys.US
Maddawg46
Central valley, CA
I have the premium Dish 500 system at home. I bought this small portable satellite dish to use in my travel trailer while I'm traveling.. I am using the Dish VIP211 box. When I adjust the dish and do the directions like Winegard gives, I get channels but can't find local ones . I also don't get all the ones I get at home. I am using 119 west, system 300. I am currently in Idaho and using that Zip code.
At home we have HD and use sattelite 129 and Dish system 500.
How can I get the local channels and the channels I get at home? I have done the check switch and have a green signal with about 25 % signal strength.
Some of your channels are on 110, some are probably on 129. Isn't that dish a single satellite dish, where you can only pick up one satellite at a time? If you're pointed at 119, you'll only get those channels which are on that satellite.
Also, if you're outside the spotbeam area for your locals, you won't get them at all.
Tree growing
Dish and Cable on same line in RV
