Winegard 100CM vs 76CM Dish | SatelliteGuys.US
WRBreland
39
Can someone with a 1M dish and a Twinhan 1020A or 102G check their Signal Level and Quality on the following satellite:
Satellite: AMC–3
Transponder: 21
Frequency: 12128
Polarization: H
Symbol Rate: 14028
I have a Winegard DS-2076 (76CM) dish and would like to know if it would be a worthwhile improvement to get a Winegard 3100 (1M dish).
Receiver: Twinhan 102G (installed in HTPC)
LNB: DMS International ASC321 (purchased a Invacom SNH-031 but the ASC321 works better).
Signal Level: 69%
Signal Quality: 59%
Wendell
Hi,
I managed get AMC4 on my WineGard 100cm but wanted how do you set the elavation on the darn thing.
With 76cm WineGard theirs a red line to indicate the current elevation but not on the 100cm one.
Could someone please tell me correct process for setting elevation for 100cm.
I need setup another for some friends but cannot figure it out.
I managed setup their 76cm for RTPi but would rather use their 100cm one.
Thanks,
Tony :)
With the 1 meter Winegard you line up the elevation nut to the required angle, as always the elevation angle should be peaked in using your signal quality mater.
Anyone heard of or used 'Big Sat' LNBs?
How Do I Post A Picture On the Forum?
