Will this LNB work for Star Choice? | SatelliteGuys.US
iceman31
Canada
I have an old round dish from my Express Vu Days. In fact It is so old that the old Express Vu LNB actually worked for Star Choice. Well since I went to HD and I went to the oval dish I had stored my old dish in my back yard. Well someone stole the LNB from it. I was going to give it to my brother but now have to find a LNB for it. Will this LNB work?
0.3db Standard Linear Ku LNB HD Ready & LNB Bracket
Do a search on ebay for item ID 360159466111 as I tried to post the link but it would not let me.
Do any of you know where I can find an LNB at a really cheap price?
Brother will be using it with a DSR500. This DSR500 has been in the past hooked up to a Oval Dish - Will stacked - non stacked come into play? What do you think the above LNB is - probably non stacked????
yes that LNB will work fine and it is non stacked LNB. The old ExpressVu LNB was also non stacked so there shouldnt be an issue
I have one of those EVu LNB's still...work great for FTA
If your brother has an issue with the 500 and it thinking the LNB is stacked, just call up Starch....errr Shaw Direct and tell them its "non stacked"
hard to see in the pic but its on the far right dish
Shaw Direct Free View for June
Starchoice setup with acutrac 22
