On Wednesday the Directv installers will be here. I have taken a picture of the only spot in my yard that might work for getting LOS. There's a gap between two trees for getting LOS. Will this work.
If you have a smart phone, you can download a dish pointer app that will tell you exactly where the bird sits
If the sats are exactly between the trees, Yes.
Remember the signal come in much higher than you would think and bounces of the reflector into the LNB.
I got the Dishpointer Augmented for $10. Worked well for me when I used it. Had to put a Dish up at our place in MammothWhich one do you recommend ?
The DishpointerPro is like $ 20
Is that the one you mean ?
Here is screen shot I just now took from my backyard using Dishpointer AR on my phone
I tried a compass on the android a few weeks ago and found the same issues.not sure. I know my buddy has a compass app on his iPhone and its somewhat slow, clunky and not accurate enough. Not sure if there is more than one app tho.
From what I read, the only difference between the pro version and the $10 version is this:I think so, I cannot find that one on my Android Market selection.
I'm finding Dishpointer Pro for $ 20.
Anyone know the difference.
Also, do you need to d/l a compass for the phone as well for it to work ?
Why get the Pro version?
+ Add your own satellites to the list, update them whenever you want - complete independence when satellite positions change or new ones appear - no need to wait for an official update. For business critical missions a must.
+Be on the safe side for future updates and new features. Pro version always take priority over the standard version.
Too me this is not worth paying twice as much for basically the same thing.
I can say that the Dishpoint AR app works very well and is not slow at all.not sure. I know my buddy has a compass app on his iPhone and its somewhat slow, clunky and not accurate enough. Not sure if there is more than one app tho.
Limited time offer
