Will this EHD work with my VIP722 ? | SatelliteGuys.US
It will, but you will need to disable it's sleep mode. I'd look for a WD same price or probably cheaper. The 722 will take over the formatting. No partitions.
I would also choose a WD over a Seagate. But yes, it will work, very important to do what KAB said and disable the sleep mode.
Just bought one of the Seagates last week.
I ended up moving my Western Digital off of my computer to use for 722 and putting the Seagate on my computer.
Someone had mentioned that the Seagates used multiple platters and Western Digital uses only one.
Since I did not want to take any chances I used the WD drive.
It is true that Seagate uses multiple platters, but I am not sure if it is true that they cause problems with the Dish boxes supporting them.
Just my two cents.
Multiple Receivers
Dish Pause for weekend home
