Will Raising my antenna 8' help? | SatelliteGuys.US
JerryK
212
Hi All,
I have a 2 story house and my antenna (standard uhf/vhf with rotor) is on the garage, about 15' off the ground. With my DTV tuner I get most of the locals I should get, except one weak one. ....but rain hoses me.
Today I'm going to put it on top of the main house, raising it from 15' to probably 23' off the ground. Should I see some improvement?
If not, will going to a "committed" uhf antenna (no vhf wings on it) help noticeably?
Again, I get my locals ok, just trying to make the reception stronger and reliable.
Thanks,
Jerry
Well when it comes to standard antenna's the higher the better. Sat dish just need a clear view of the target.
It is not unusual fro OTA digital signals to exhibit "holes". there will be places where signal is very low and places nearby where signal is acceptable. If it's not too dangerous, mount your antenna on a 5-10 ft pole and walk around on the top of the house to find the optimum location.
I know wher there are a couple of properties, in the area where i live, where there is NO Signal for 4 stations that have towers less that 15 miles from it; BUT I could get VERY GOOD reception for a couple of stations from OVER 60 miles away!!!!!!!!! I found this out by walking the property with an antenna. I call it the BLACK HOLE EFFECT >>>> LOL
OTA and 622 Dropping Signal
Indoor antenna works at one place but not the other?!?
