The title says it all. I plan on using this with my tripod setup on a 1000.2 dish. I also plan on using this with my Hopper 3. I know I cannot use them at the same time.
The Hub is needed for adding a Joey to the Hopper. It would not be needed for the Hopper by itself, and it definitely would not be needed for the Wally. The DPH LNB is all you would need.Will I need anything else? It comes with a solo hub.
Replace those DP34's with DPP44's. The DPP switch technology should allow you to use those Wally as dual-tuner receivers without causing any problems.I have 6 Wallys that we're connected to a pair of DP34s. They were single tuners at the time of install. Now they show up as dual tuners and I can't get all 6 to work. Any ideas on how to resolve? I called Dish and they didn't know how to downgrade the software
There is no waydo you know of any way to force the wallys back to single tuner mode
The only way that I can think of would be to replace them with really old Wally receivers, still in the original box, that came pre-loaded with U420 or earlier software. Even then, as soon as they download the new software, they would immediately be upgraded to dual-tuner status again.do you know of any way to force the wallys back to single tuner mode
Can you give me the contact information for the MDU team, from whom you received this reply? I have been having an account-level issue with any Wally on my account, where it disables DVR functionality and adds a "D" to the model field in the Diagnostics screen. I am now having the same issue with my Hopper Duo. I would prefer to email them first, instead of calling the number you listed, if they are only set up to deal with commercial accounts at that number. My account is not a commercial account, but it is apparently being treated as such. Nobody at the regular Dish customer support (that I have contacted anyway) seems to be able to remove this incorrect tag from my account.Here is the official answer from Dish MDU Team where Un-stacking is more common.
"Sorry for the delayed response. By default the Wally is a dual tuner receiver, you can turn it into a single tuner by adding the Disable Tuner 2 Code to the account. When the receiver has this authorization you will see a Comm T added to the model field in the diagnostics screen.
that 800. Umber is the best wayCan you give me the contact information for the MDU team, from whom you received this reply? I have been having an account-level issue with any Wally on my account, where it disables DVR functionality and adds a "D" to the model field in the Diagnostics screen. I am now having the same issue with my Hopper Duo. I would prefer to email them first, instead of calling the number you listed, if they are only set up to deal with commercial accounts at that number. My account is not a commercial account, but it is apparently being treated as such. Nobody at the regular Dish customer support (that I have contacted anyway) seems to be able to remove this incorrect tag from my account.
Well since the "Comm T" disables the second Tuner, and the "D" disables the DVR, those codes seem fairly straight-forward. I have also seen codes "A" and "Comm A" but I have no idea what gets disabled when those codes are applied.I will attempt to find out what the D refers to
Glad you got it going, hopefully not tagged comm for Commercial. The A code isThe 888 number worked like a charm! There was indeed a "disable DVR" tag on my account, and they were able to get it successfully removed. So now I finally have DVR functions back on my Hopper Duo. I still have no idea how that tag got put on my account in the first place, but as long as it does not reappear, I am happy. The weird part is that the entire time, even with this "D" tag on the account, DVR functionality continued to work on my ViP211k just fine. So, whatever this tag does, it only seems to affect Hopper (and Wally) receivers.
So to finalize this discussion if you want your Wallys to be in single tuner mode Dish can and will put the T code in the system which will put it back to operation as if it was a 211.There is no way
It would also allow 32 Wally's on a single DPP LNB, hooked up through a DPH42 switch.So to finalize this discussion if you want your Wallys to be in single tuner mode Dish can and will put the T code in the system which will put it back to operation as if it was a 211.
which will allow 16 Wally's on a DPH LNBF all on a single wire!
Limited time offer
