Will a high frequency splitter will do ??? | SatelliteGuys.US
sksatellite
616
Ok. here is the question, when we use 2x1 or 4x1 DiSEqC switch, but we wanted this to multi receivers, maybe three or four rooms, can this will work if uses high frequency splitter to four rooms receivers. Or there some kind of switch we can use.
You can split the line at the LNB to go to 2 receivers, but whatever your main one has for polarity, the others follow : )
If you have a dual LNB and want to run 3 receivers, you can use a DirecTV multiswitch. I did that on G10 for a while
If you turn one of the boxes completely off, the other should be able to control both H & V. That is how I work my 2500A and Coolsat. :)
The Tube
Tripod Question
