billinmidmich said:Will a Digiwave DGS-03S work for Dishnet?
Right they do work.....thats what I have....the noise factor is probably 0.6 or 0.5....the Digiwave is 0.3. I have already improved signal by 20 by just going to a 31" dish. Want to see how much better with a better LNB.stone phillips420 said:a dishnet legacy lnb or dishpro lnb will work fine for dishnet.
Can it work with the DP34 switch?boba said:It definetly won't mount in a standard DISH Network dish. It might work as a replacement for a LEGACY LNB it does not support band stacking as a Dish Pro LNB.
I'm not even sure it would work as a Legacy LNB it uses voltage switching and covers the frequencies needed but I don't think it is circular polarization, it is probably just Horizontal /Vertical seeing most FTA is FSS.webbydude said:I seriously doubt it would work with a DP34. Once again, the bandstacking requirements.
Just a wild thought...I wonder if a D* 34 switch would work tho. Essentially, they're Legacy equipment.
Limited time offer
