WIFI ISSUES WITH LATEST SOFTWARE | SatelliteGuys.US
Chewie
352
199
California
Hello Gentlemen
I just downloaded to the latest software on my Azbox-plus, I haven't seen that many issues with it.
It seems to be working pretty good, except the WiFi connection, the router has assigned the IP address to the box, I have it set up for WiFi and DHCP, so the router is connected to the box.
The problem I'm having is that, I'm not able to to communicate with my computer to the box using MaZ orAzboxtoll editor, I have Windows 7 and with the previous software it was working fine on just wondering if anybody out there have this issue after the upgrade.
Maybe I have to setup my home group again.
any comments will be appreciated.
best regards.
Chewie
Hello Gents
I found the problem, after the software upgrade I did a factory reset, I forgot to enable the FTP Server and the Telnet Server, I set them both to Enable and everything is working now.
regards.
Chewie
Hello Gents
regards.
Chewie
Thanks for updating. This will come in handy for someone else.
You Tube Gone Again as of Aug. 4th.
azbox error 1
