Why is Collsat 4000 Pro twice as much as Fortec? | SatelliteGuys.US
mchomicz
SatelliteGuys Guru
Why is it that the Coolsat 4000 Pro almost twice as expensive as Fortec Start Lifetime Ultra? I've read the features list and a review or two - but I don't get it. What is it about it that makes it TWICE better?
Thanks,
Michael
your choice......nobody is forcing you to buy a particular receiver :)
I just used 2 companies above that are reputable and sell those units...
Just like with anything in life, look at the options and choose accordingly :D
by looking at the specs, the processor is much better in the Colsat than the Fortec
(using your two links above)
I have a Pansat 1500 (little brother of the 2500 which is like a Fortec) and just got a Coolsat and I really like the Coolsat better...very easy to work with and the blind scan is much faster. Also, with the Fortec you have to clean out the TP's stored on a regular basis or the unit does some funky things.
Switch Recommendation Anyone?
User manul for Pansat2700a?
