I would have to disagree. I will jump back and forth quite often to try and multiplex two shows at the same time (i.e. Poor man's PiP). This is especially true with sporting events.BFG said:^^^^
What he said
There's absolutely no reason why you should be "channel flipping" on satellite
Ilya said:Welcome to the forum, MrP!
Note, that digital channels always take longer to switch, due to the way MPEG-2 compression works. Even on cable. If you had digital cable, you probably noticed that it takes much longer to switch between digital channels (usually above 100), compared to switching between analog channels.
RandallA said:"My problem is that the satellite guys used the existing cable cabling for the satellite installation."
You can combine the satellite signal and the cable signal using diplexers. You will need a pair of them.
MrP said:Thanks for the education. Do you know how can I obtain more information in how to do that?
Limited time offer
