Why do I keep having issues with sat. 118? | SatelliteGuys.US
etong
New Jersey
I had a tech came out and realigned the dish about 2 weeks ago, the signal strength went up to 40+ on average. Now it drops back to average 15 again. We had heavy rain today, but that ended hours ago. I don't understand what is wrong with this particular dish or satellite. On all the other satellites, I'm constantly getting 50+ signal strength, or 40+ during bad weather. I'm really getting frustrated with this.
118 is a different type of satellite (FSS) so it has a lower signal strength requiring a larger dish that is why you are getting a lower signal than the other DISH satellites.
PROBLEMS YOU MAY HAVE:
Bolts not tightened on dish allowing it to move.
Mounting foot not correctly anchored to roof/building.
Bad cable connection allowing water ingress.
Bad LNB
Bad switch
"Bad cable connection allowing water ingress." Based on the OP, I'd start there.
Home Media Slideshow Hangs on Some JPG Images
Remote on Hopper Not very responsive
