Why can't I get Channel 515? | SatelliteGuys.US
jerryez
4,751
1,308
Pensacola,FL
I tried to redeem a coup[on for a HD PPV movie on channel 515 and the order system said to check and be sure I could get channel 515. I checked and it is not available. Why can't I get a HD PPV movie on channel 515. The movie I want is only in HD on channel 515.
if your signature is correct, then i have the answer. you can't get 515 because your aren't looking at 129° according to "The List" that is where 515 comes from.
It's on EA, "72" or 129. I have both EA and 110,119 ,61.5, I had to switch over to EA last week to be able to get Alice in Wonderland in HD for $.99 cents because it wasn't on the 110,119,or 61.5.
Thanks, That sucks, but I will not pay Dish to change me to EA when they should do it for free, since they are the one moving channels away from 61.5
Can you use a coupon code with VOD on 501
General RSN Question
