Wholehome not working | SatelliteGuys.US
rjohn152
2
georgia
So the tech guy just left, and I was stupid enough not to test the system before hand. I called directv and they said the tech would be back tomorrow, but if i can get a solution tonight that would be amazing. So the dish is one line going into a green label swm8 switch. From there it goes to three h25s and an hr24. before going into the hr24 the line is going into an swm power inserter. The problem is that the receivers wont connect to each other. From what I understand the 24 and 25 models have deca built in. One site seemed like i need to connect the receivers to the home network, though i am pretty sure this is not the case and there aren't any cat5 currently connected. When I called, directv did confirm that the mrv was activated. Any help would be useful.
Thanks!
That worked!!! I didn't realize that the network restore defaults would be different from the other one. Now I can call off the tech. Thanks!!!!
40 channels for $40
Upgrade from old SD dish to 3 LNB Slimline SWM Dish
