Whole Home / TV Question | SatelliteGuys.US
doug4772
39
Lewistown, PA
I am upgrading to a whole home DVR system next week. I will transition my HR23 to my upstairs tv and have a new HR24 installed in my living room.
My question is, if I use an RF Modulator can I connect the HR23 HD DVR to an SD tv? I believe this will work. I know it's not ideal but I need to connect it this way until I buy an HD tv for my second room.
Essentially, the RF modulator will allow me to convert svideo from the receiver to straight coax. I suppose could use composite RCA cab,cables as well...
Thanks,
Doug
Most RF mods ONLY take composite video in.
Just curious, but you're sure your SD TV has NO external A/V inputs already, front or back? If so, you obviously would NOT even need the RF mod.
Thanks,
Doug
Does the HR23 have an s-video out? BTW, a VCR makes a fine rf modulator!
The TV is coax input only. The HR23 does have svideo output.
The radio shack RF modulator I already had does have composite and svideo.
Sounds like I a set for now.
Thanks for e replies.
-Doug
How to tell if my equipment is capable of HD + need LNB
different bird for local channels?
