Which UHF remotes work with 612 receiver | SatelliteGuys.US
mfs54729
96
Chippewa Falls, WI.
I just got a 612 receiver. I mounted the receiver in a closet so I need to use a
UHF remote to access it. I'm looking for a couple more remotes. Which UHF
remotes will work with the 612 receiver?
Thanks.
Mark
Guys, get the 21.0 from Ebay or Amazon. Paid about $18 shipped from Ebay, it works great. Getting it from Ebay or Amazon assures you will get the remote you want.
If you use the 21.0 you will be using the UHF "B" instead of the UHF "A".
If you recently got the 612, they now ship them with 20.0 ir remotes only. That being said, if you do buy a 21.0 remote, be sure to get an antenna too. Since they went to the IR remote, they no longer include the antenna in the box.
Dish 2 go
Recomendation for Which Satellites to Use
