Which software for the StarBox VP-7021? | SatelliteGuys.US
ken2400
1,309
144
Central NY State
Just wondering what software will work with the Twinhan StarBox VP-7021 usb box?
I have mytheater working now.
Any others? What drivers would I need if any?
It's been a while , but I thought ProgDVB was supposed to support it.
Don't think I ever got it to work... probably my fault.
I did get MyTheatre to work pretty well. But only after lots of blood sweat 'n tears.
Later (a year ago) I went looking for something better, and my first choice, DVBdream didn't do the Twinhan USB.
Well, it might have handled the "A" model, with BDA drivers, but that's not what I had.
So, I moved on to a PCI card...
...and eventually a stand alone FTA receiver.
edit:
Oh, here is an old discussion of such things. Give it a read.
Thanks for the info Anole. I do need to pull the box apart. It does overheat.
Anyone else have software ideas?
Thanks again
edit:
What a bum design! The box REALLY needs more vent holes!.
I like how there is a second cable connection that can be used on the tuner.
It was easy to open so I hope all works well now.
Galaxy 25
Ka band on big dish?
