Which Sats for my area. | SatelliteGuys.US
mikfro
7
memphis, Tennessee
Help!! Which sats should i be getting for Memphis Tennessee 38122 I seem to be having a problem with the HD channels. Should I be able to get a signal from all the sats and all transponders ? If not which sats do i need to fine tune? I am waitng on 2 new B-Band Connecters to see if that may be my problem. I have a hr22-100 box and 5lnb dish. I am just wondering which sats and transponders I should be getting. I have noticed that some posts say some areas dont get all sats or transponders.:confused:
my transponder readings
101 110 119 99c 99s 103s 103ca 103cb
1 97 na na 71 0 0 na 0
2 97 na na 71 42 0 na 84
3 97 na na 72 18 0 na 0
4 97 na na 74 0 0 na 82
5 97 na na 69 26 0 na 0
6 99 na na 73 72 0 na 83
7 97 na na 73 na na na 0
8 99 94 na 74 na na na 83
9 97 na na 73 na na 0 0
10 97 96 na 76 na na 76 85
11 97 na na 78 na na 0 0
12 0 95 na 82 na na 77 86
13 97 na na 83 na na 0 0
14 100 na na 87 72 0 69 84
15 97 na na na 25 0 0 na
16 100 na na na 77 0 74 na
17 97 na na na 82 0 0 na
18 92 na na na 30 91 68 na
19 97 na na na 29 0 0 na
20 71 na na na 0 0 69 na
21 98 na 85 na 0 0 0 na
22 99 na 0 na 65 0 59 na
23 96 na 82 na 80 0 0 na
24 100 na 0 na na 0 65 na
25 97 na 83 na na 0 na na
26 0 na 0 na na na na na
27 96 na 80 na na na na na
28 62 na 0 na na na na na
29 97 na 0 na na na na na
30 99 na 82 na na na na na
31 95 na 0 na na na na na
32 100 na 81 na na na na na
Your numbers on what would be the Hi Def side of things are low.
The 101 is fine.
Swap out the BBC;s and see if that helps, but I don't think thats the problem.
I think you need to fine tune the dish, do the dithering portion.
in regards to the transponders you will have 0 on some
I dont know which ones on 99 & 103 do but on 101 & 119 there are spotbeams. I know on 101 4 & 12 are spotbeams. If you're not within a spotbeam it will show 0. TP4 for me shows 0 too
119 has a lot of spotbeams so you may see 0's on there
n/a is because on 110 there are only 3 transponders used and on 119 only 22-32 are used. The others Dish use at the same spot (but different satellite)
30 day satisfaction guarantee
H21-100 question
