Which LNB | SatelliteGuys.US
Which LNB
I don't think 2 Dish Pro LNBs fighting will help the poster out much. A DP "DUAL" might be the correct answer meaning it has 2 threaded outputs to connect a cable to.
I don't know of any readily available dishes larger than 20" to use for both 110 & 119. He will need 2 30" inch dishes with 1 LNB on each to get 110 & 119 with an external switch like a DP21.
1000.4 Installation
Scott's new Tech Forum for Dish Network
