Which LNB | SatelliteGuys.US
Which LNB
tonydix
203
Bocas del Toro, Panama
The 6foot dish which I just bought came with a Sharp Cirunlar LNB with a diameter of about 32.5 mms which I guess was used on Dish or Directv.
Now what I need is a linear Ku LNB to recieve FTA signals but with a similar throat diameter of about 32.5 mms. Any suggestions would be most welcome.
Tony
Here is a pic of the dishLNB :-
Tony
Thanks Lak7. I just took it to pieces and found that here was a kind of spacer ring to adapt that LNB to a 40mm diam clamp.
So any 40mm LNB will work. Any recomendations ?
Tony
You are right it is the sharp lnb for dtv. I dont understand spanish very well Is it just a matter of carefully removing the flange you hav highlighted in red ?
Many thanks
Tony
Many thanks
Tony
Yes remove the Flange with a Dremel, be very carefull not to drop waste inside the throat; if you compromise the element at the bottom of the neck the LNBF will be useless.
Once you have removed the flange then you have to set up your FTA with L.O. to 10.500
Also remember now the LNBF is lineal you have to adjust also skew in order to receive.
Good Luck!!!
Special: $40 OFF Sadoun 1.8m Prime Focus C/KU Band Dishes
2x1 switch-Glorystar
