Which Compression Tool? | SatelliteGuys.US
I've got the Datashark too, but, I have had trouble finding good prices on connectors that are compatable with it.
I think I have 200, two different bags of 100 that don't work very well. :mad:
Anyone need F-connectors?
The one I have doesn't resemble either of the ones shown, I purchased it from a seller on E-Bay. It looks closer to the JVI set but not exact.
As far as ends, I found a great deal on genuine Thomas and Betts ends again from a seller on E-Bay and they work very well.
I'm not knocking any of our sponsors just passing along info. The price I paid for my ends could not be matched by a sponsor, I checked before purchasing.
I guess for $20 I just make the plunge... It's just that at $20 it is close to the most expensive FTA purchase I've made, so I figured I'd ask around :)
Thanks for the feedback.
I use two tools here, one made by Zenith (ZDS-5061) which I purchased from Lowes, and the other is a Digicon (F-Conn, ICMCorp) clone I purchased on E-Bay for BNC and RCA use. Both work perfectly well on any F-fitting I've tried on them.
The Datashark looks similar to (but not the same as) the Zenith I have...
Having Trouble With Dish at 123w Location
Get HD via the Visionsat IV200 PVR Plus (sort of)
